Road brake lever angle?
Our Community › Forums › Bikes & Equipment › Road brake lever angle?
- This topic has 51 replies, 16 voices, and was last updated 5 years, 4 months ago by
kwarkentien.
March 2, 2020 at 7:23 pm #921806
ParticipantSo I think I want to slide the brake lever on my drop bar fixie a little closer to my hands. But I fear if I do this, the lever is going to be pointing straight out like a bullhorn and look terrible. Do they make the levers at different angles? Or is there some other measurement to look at? Pull length or some such thing?
March 4, 2020 at 6:19 pm #1105005
joetats
ParticipantOne thing you can try pretty quickly is to flip the stem so that it points up; it wouldn’t have the parallel look anymore but would give you an idea of a slightly shorter reach and could point you in the right direction to if getting a shorter/less angled stem would feel more comfortable.
March 4, 2020 at 8:34 pm #1105009jrenaut
Participant@ImaCynic 199000 wrote:
Do you know what size is this bike? How much bigger is it compared with your other bike that you are comfortable riding?
Just looked it up, and it’s a 58. My Bianchi is a 57, so maybe it is just setup and not actually too big.
March 4, 2020 at 8:48 pm #1105011josh
ParticipantMy vote goes to more yoga, losing the spacers, and a -17 degree, 140mm stem.
March 4, 2020 at 8:59 pm #1105012ImaCynic
ParticipantIt’s much harder to make a larger frame fit than one that is smaller, unfortunately.
But here we go:
Here’s a bar with very short reach and shallow drop:
https://www.jensonusa.com/3T-Ernova-Road-Alloy-Handlebarcombined with a short (60mm) stem like this:
https://www.jensonusa.com/Whisky-No7-6D-Stemyou might be able to pull back over an inch of reach. Changing seat position can cause all sorts of issues with you knees, so be really careful about that. Also, I noticed a rather large number of spacers between the headtube and the stem, this can have the effect of making the matter worse. You might want to play with that to see how it affects the fit. There is no shame in stacking these on top of the stem for now so you don’t have to cut anything.
March 5, 2020 at 12:53 am #1105021EasyRider
But here we go:
I think swapping the spacers from under the stem to over it wonÂ’t give you joy. It will lower your bars, and I think too-low bars is actually the main problem here, given how much lower your bars are than your saddle in the picture.
Removing spacers under the bar and using a shorter stem will to some degree cancel each other out. ThatÂ’s because as a bikeÂ’s stem and handlebars are raised, they also get closer to the rider. As they are lowered, they also get farther away. Picture looking at the bike from the side, as the stem and handlebars move up and down an imaginary diagonal line through the head tube.
March 5, 2020 at 2:52 am #1105025ImaCynic
Since the bike is actually not that much bigger, having the stem so elevated can throw off proper positioning. One way to “shrink” a frame is to increase one’s back angle, but this would result in a awkward hand position with how high the stem is. This is why stem height should be part of fitting process. Besides, if asthetics is in the equation, that stack of spacers is a definite no go.
Sent from my moto x4 using Tapatalk
March 5, 2020 at 3:05 am #1105026EasyRider
I get your point, but I think “proper position” is a relative term in this case, which seems to be about jrenaut finding a comfortable fit, not a performance one. The stem and bars are several inches below the saddle already, and there’s a lot of seatpost showing, which is not usually a sign of a too-big bike. It looks to me like the bike is already set up for a performance-oriented fit, but it isn’t comfortable that way.
March 5, 2020 at 2:25 pm #1105028SarahBee
Spacer hater! My stack is bigger than your stack.
March 5, 2020 at 2:49 pm #1105033ImaCynic
1cm should not make a big difference. Assuming you are satisfied with the fit of the Bianchi, can you do the following measurements on both bikes?
1) Distance from the center of the crank to the top of the saddle at where the seatpost would intersect, measure parallel to the seat tube
2) Horizontal distance from the front tip of the saddle to the centerline of the stem/handlebar, I suggest project/extrapolate these to the toptube and measure from there.
March 5, 2020 at 2:55 pm #1105034ImaCynic
Slam it baby, slam!
March 5, 2020 at 4:17 pm #1105035EasyRider
ParticipantOP, whatcha gonna do? Fit the bike to your body? Or fit your body to a bike set up for racing 18mph+ on an open course?
March 5, 2020 at 4:24 pm #1105036jrenaut
ParticipantI’m going to try flipping the stem over and see how that is.
March 5, 2020 at 4:57 pm #1105037chuxtr
ParticipantMarch 5, 2020 at 5:49 pm #1105041loki
+1
And lose the brakes too
Sent from my SM-G960U using Tapatalk
March 5, 2020 at 11:27 pm #1105046SarahBee
Participant@loki 199054 wrote:
+1
If we’re losing brakes, who needs gears? One should be plenty, especially for a kid-hauling bad-ass. This could be a really great velodrome contender! We all know Jon is a closet track bike skin suit kinda cyclist.
