Recurring flats
Our Community › Forums › Bikes & Equipment › Maintenance › Recurring flats
- This topic has 18 replies, 10 voices, and was last updated 12 years, 11 months ago by
ShawnoftheDread.
July 11, 2012 at 11:41 pm #945507
ParticipantAny burrs in the rim that might rub things the wrong way? Try a round of electrical tape on top of the rim tape.
July 11, 2012 at 11:45 pm #945508jopamora
ParticipantNew breed of bike air sucking mosquito? Sorry, not being helpful other than thinking outside the box.
July 11, 2012 at 11:49 pm #945509ShawnoftheDread
I don’t think so, but that sounds worth a try. Thanks!
July 12, 2012 at 12:41 am #945518off2ride
ParticipantIf you get another flat, before you remove the tube, mark the tube in relation to the wheel and tire. Tank it if you have to to verify if it’s a slow leak then go from there. A magnifying glass might help.
July 12, 2012 at 2:41 am #945524ShawnoftheDread
Thanks. I always mount the valve stem in the center of the tire logo so I know where to check the closest for sharps.
With all three flats I found the puncture pretty easily-they weren’t slow.
July 12, 2012 at 2:47 am #945525off2ride
ParticipantAwesome. Most bike stores mount the tire logo above the valve for cosmetic purposes and for locating punctures.
July 12, 2012 at 12:36 pm #945538Tim Kelley
ParticipantI’ve had two different friends have similar issues as you in the past week or so. The first one ended up having a sharp spot on the rim around the hole for the valve stem. He was able to file it down and that solved the problem.
The second friend was riding the W&OD, got two flats on the same tire, but made it to the Trails End bike shop in Purceville. They took a look at it, but couldn’t find anything and sent him on his way. He flatted again twice before he got to Leesburg and had to get a ride into the Tri shop there. He got a new tire, and rim strip and it seemed to clear things up.
July 12, 2012 at 4:32 pm #945583creadinger
Participant@Tim Kelley 24974 wrote:
The second friend was riding the W&OD, got two flats on the same tire, but made it to the Trails End bike shop in Purceville…..He flatted again twice before he got to Leesburg and had to get a ride into the Tri shop there…
Sheesh, this person has patience. If that had been me, you would have found my bike tossed into the woods and I would have taken up jogging.
July 12, 2012 at 4:40 pm #945586ShawnoftheDread
Fixing flats is still better than running.
July 12, 2012 at 4:55 pm #945591Tim Kelley
He desperately needs the miles for Ironman training.
July 12, 2012 at 5:18 pm #945599mstone
RIDING ON flats is still better than running.
July 12, 2012 at 6:16 pm #945612DSalovesh
ParticipantKidding I’m sure, but I’ve done it when I have no other alternative:
Fresh out of college with most of an arts degree (i.e., beyond broke) I got a flat and had no money for a tube, so I kept riding it for a couple of weeks. Then I got another flat and still had no money for two tubes. I think I kept that up for almost two months until I got laid off (after letting OSHA know we were working with asbestos and had been given no instruction or safety equipment) and it started getting snowy.
Come spring I had a far better “day job” so I bought a couple of tubes to get back on the road and see if I needed new tires or wheels – but I didn’t. Everything was fine and the wheels didn’t even need truing! The tires were well worn from the previous couple of years of riding but they weren’t quite used up or damaged. Replaced them a couple of paychecks later, but the wheels themselves (Mavic MA-40s on Campy Triomphe hubs) kept rolling for many thousands of miles and at least 10 years.
July 13, 2012 at 11:28 pm #945774ShawnoftheDread
ParticipantAnother flat coming home today! Blurg.
July 14, 2012 at 2:14 am #945791jordash
ParticipantAre you new to installing tubes? Perhaps you’re pinching the tube when you’re installing it. At this point, perhaps you should buy another tire and try it out. If you stop getting flats, there’s definitely something sharp in that tire. If you keep getting them you’ve ruled out one source (and still have a replacement tire), which makes the rim the likely culprit.
July 14, 2012 at 2:55 pm #945799ShawnoftheDread
No, I’ve been installing tubes since I was a kid. And the holes are all on the rim side. Yesterday’s flat was two small holes – looked just like the adjacent spoke nipple.
