Habanero ti ‘cross/gravel/touring frameset + extras
Our Community › Forums › Classifieds › Habanero ti ‘cross/gravel/touring frameset + extras
- This topic has 36 replies, 13 voices, and was last updated 6 years ago by
josh.
April 21, 2017 at 1:02 am #919309
ParticipantI have my new travel couplers frame now, so am going to move over my components and sell my current commuter/gravel frame, along with the Spot full-carbon fork (pictured) and my Flo30 wheelset (pictured) and a spare-but-dented-rim Grail wheelset (for parts or winter or just riding since it is still works fine).
59cm
https://www.habcycles.com/cross.html
This frame only has ~5k miles on it. It was a a warranty replacement last year.
Important: I’ve made a few “mods” to frame: (1) drilled out cable stops for full-length shifter housing and hydro hose; and (2) I removed the cable stop on back of seat tube for the front derailleur (so I could mount my light on the seat tube to free up my seatpost for Weehoo hookup, etc.) — This means the frame is 1x only (unless you use a problem solvers cable stop).
I love this frame, but I have no room N+1. It is perfect for gravel. Heck, it won Monster Cross Open CX this year!
I am posting this now before I strip off the components in case anyone wants to ride it.
A few notes:
– Full rack and fender mounts.
– ISO disc mount on frame. Frame clears 160mm rotors no problem; that’s what I’m running. Post mount on fork for 160mm minimum. (Not sure if frame or fork would clear rotors larger than 160.)
– Clearance for 700x45mm tires in frame & fork. Frame looks like it’d handle 27.5 x 2.0 (or more?), unsure on fork.
– 27.2mm post. Seatpost binder works great, but is picky on seatpost size tolerance. (E.g. I use carbon paste not grease with the Syncros ti post I’m using now.) .
– 68mm BB shell. I am using a road double with a 44t Wolf Tooth chain ring. That clears fine, but a 46t X-Sync chainring barely does not clear the chain stay. (X-Sync are offset inboard by 2mm) . The X-Sync ring would work with a wide crankset (e.g. MTB width) or works with a 2mm spacer on outside of this particular crankset.Details on wheelsets:
– Both wheelsets use same [mismatched] Hope Pro2 rear + DT Swiss 240s front hubs. The Flo30 has a blue rear hub; the Grail has a silver rear hub. They are loud hubs and I love that they don’t match, but I realize that’s not for everyone.
– The hubs use 135x10mm and 100x9mm DT Swiss RWS “thru-bolts”. I.e. they fit in QR frame + fork, but are thru-axles. (This is supposedly stiffer.)
– The rear hubs cannot be converted to road 11sp (though you can put some Shimano 11sp MTB cassettes on there or get SRAMdriver). Or I hear Jan at Bikenetic can make them 11sp compatible with a Dremel.
– The Flo30 wheelset uses CX-Ray spokes. The rims are in good shape, but have a couple of surface scratches. They’ve been used for many thousands of miles now (20k?) but not off-road; never had to adjust them. Expect them to keep going forever. I am running these tubeless.
– The Grail rims have a few dents, one significant (mostly the rear). They still seat up tubeless just fine and I don’t hesitate to ride them. These rims are generally known to be a bit soft, I guess. (They are probably my favorite rims form a build perspective, though. And the tubeless performance is fantastic.) . If I was keeping the wheelset, I’d just replace the rear rim and be a little more careful not to run such low pressure off-road. (But my new frame is thru-axle, so it doesn’t make sense to keep the wheelset.)Forum price $500 for frame, headset, fork, Flo30 wheelset, Grail spare-parts wheelset. I’ll include the stainless cages (pictured) and a stem in 100mm or 110mm sizing if you’d like.
Will post more details and better photos when I disassemble it next week.
April 21, 2017 at 12:01 pm #1069696ian74
ParticipantWow! hozn, that is a steal for a Ti frame with TWO wheelsets. The frame alone is worth a lot more than your asking price (as you know). I bet Judd would be interested! If you were like 3 feet shorter I would have jumped this.
If it doesn’t sell here, someone in the DC used marketplace group on Facebook will take this off your hands in a heartbeast.
April 21, 2017 at 12:19 pm #1069697anomad
ParticipantBetween the 3 of us at home we have bikes coming out our ears. But man I’m tempted.
April 21, 2017 at 12:28 pm #1069699huskerdont
I am tempted as well. That is beautiful and would fit. But I dunno if I can justify riding a bike that won a category at MonsterCross. That horse would just be impatient/disappointed with my riding.
April 21, 2017 at 1:59 pm #1069703hozn
. It was just a nice confluence of fitness and a thin field. The horse would be happy to be ridden and not sit in my basement!
P.S. I’m dropping the forum price to $500 in case that helps
. It’d be a fun project!
April 21, 2017 at 2:10 pm #1069705jrenaut
Can you drop the size down too, it’s a little too tall for me
April 21, 2017 at 2:11 pm #1069706Tania
Totes. I’m running a SRAM 11-Speed cassette on a 10sp CK hub. (He dremels down the back of the cassette, not the hub…)
April 21, 2017 at 2:13 pm #1069707LeprosyStudyGroup
ParticipantAt that price I’m considering buying these shoes to maybe be able to fit on the bike!
[IMG]https://cdn.shopify.com/s/files/1/0982/0722/products/YRU_LowKey-Hologram-Platform-Shoes-SILVER_SIDE_large.jpg?v=1484967141[/IMG]April 21, 2017 at 2:17 pm #1069708Judd
Judd is indeed interested as long as he can hop on it and make sure that the frame feels before all the parts that make the bike move are stripped off. Will PM.
April 21, 2017 at 2:20 pm #1069709hozn
Oh, interesting. For GB he dremeled down the freehub body on some Hope Pro2 Evo hubs (same hubs). So I know it can be done, but I’ve been happy sticking with 10sp for now on this bike.
April 21, 2017 at 2:20 pm #1069710huskerdont
I’m at N+1 = 7 right now and absolutely must sell one before I can do anything. Then I’d also have to sell my current gravel bike, and my SO isn’t going to understand that since it’s pretty new. “But just look at it!” would be my only defense. It would be a definite upgrade to the Masi.
April 21, 2017 at 2:49 pm #1069714Birru
I’m both jealous and relieved that I’m too short to fit this frame. I’ve never ridden Ti, and if you get the Hab I’ll be very curious about your thoughts on the ride of that Ti frame vs your aluminum and carbon machines. What are your tentative plans for the N+1?
I’d probably stick to 10-speed, maybe Tiagra with an 11-34. But for 11-speed conversion I’m more familiar with the idea of modifying the cassette, as seen in this video (jump to 3:04):
[video=youtube_share;cazQt5oleo4]https://youtu.be/cazQt5oleo4?t=3m4s[/video]
April 21, 2017 at 6:30 pm #1069730Judd
Tassles. Lots of tassles. And shredding some gnar. I will likely shred all the gnar.
April 21, 2017 at 6:52 pm #1069731Judd
But, more seriously, the fun in building a bike is doing all of the reading/researching. Round these parts, you can usually just post, “I’m building a bike” and then let the techies discuss hundreds of possibilities.
April 21, 2017 at 10:33 pm #1069741anomad
ParticipantI’ll take it.
I’m buying it out of general principle. And I rode home with Ian who said he’d never speak to me again if I didn’t buy it.
