Front light protocol and safety
Our Community › Forums › Commuters › Front light protocol and safety
- This topic has 21 replies, 16 voices, and was last updated 13 years, 3 months ago by WillStewart.
October 27, 2011 at 2:03 pm #931547Joe ChaplineParticipant
This might be obvious, but I haven’t seen it mentioned. I keep the handlebar-mount adjusted so that I can change the angle of the light, and I point it down when that’s appropriate. That seems easier than covering the light with my hand. I’ve never had a problem with the mount getting looser with any of the lights I’ve used.
October 27, 2011 at 2:34 pm #931556JimF22003Participantthe new Serfas light I bought is designed to pivot left and right, so it’s easy to aim off to the side. It’s fixed vertically however. One nice thing about the magicshine light with the o-ring mount was how easy it was to shift up and down.
I do that as well. It stays reasonably well adjusted but sometimes bumps can jar it a bit, better to be pointed a bit low than high. However, unless you adjust it constantly, I still think it is better to cover with your hand because subtle elevation changes can be the difference between blinding somebody (especially when you are going slightly downhill and somebody is approaching you coming uphill) or not. Think about it when you are driving a car as well, a car approaching you from a higher elevation will appear to have its high beams even though it does not. The same principle can occur on a bike.
October 27, 2011 at 7:17 pm #931580rcannon100ParticipantI would simply say Tip of the Hat to all y’all thinking about this and taking consideration. It’s a good thing to be thinking about how our biking, even when we are trying to be safe, impacts others.
October 29, 2011 at 8:10 pm #931703WillStewartParticipantFor visibility from the side, does anyone use Monkey lights or the equivalent?
[ATTACH=CONFIG]439[/ATTACH]
October 30, 2011 at 2:05 am #931704StopMeansStopParticipantVis 360 on the helmet, which has front, side and rear lights. I use blinky mode on trails and roads at dusk. At darkness I use high or low on trails only and blinky on roads.
Handlebar has a minewt. Blinky on roads, high/low on trails after dusk. I try and aim all lights away from trail users.
Drivers that might threaten my safety or right of way get the helmet lights RIGHT IN THEIR EYES.
October 30, 2011 at 12:43 pm #931706WillStewartParticipant@Dirt 9645 wrote:
One more thing for people who are really distracted by approaching cyclists lights… Wearing a cycling cap with a little visor under your helmet can allow you some protection. You can tip it down enough so that you still have good view of the road in front of you, but you’re not having to look directly into the approaching headlight.
This also helps to keep the morning/evening low angle sun out of a person’s eyes, especially on a recumbent.
