Front Derailleur replacment?
Our Community › Forums › Bikes & Equipment › Maintenance › Front Derailleur replacment?
- This topic has 29 replies, 6 voices, and was last updated 13 years, 6 months ago by Jsnyd.
June 9, 2011 at 12:41 am #910019JsnydParticipant
My front derailleur has an issue. excuse my explanation if it gets hairy, I’m not familiar with biking jargon just yet or correct part names for that matter :p when changing gears on my front sprockets, I can’t go from 1 through 3. I try and adjust the derailleur and cable but only get 2 and 3 or 1 and 2. There seems to be a lack in the amount of travel I need. is it possibly bent or just crappy? I’ve messed with it so much that my gear indicator doesnt even know what gear im in anymore.
June 9, 2011 at 2:43 am #926667RESTONTODCParticipantI’m not an expert but my guess is the limit screw. I need to adjust them.
Good luck
June 9, 2011 at 2:43 am #926746RESTONTODCParticipantI’m not an expert but my guess is the limit screw. I need to adjust them.
Good luck
June 9, 2011 at 8:55 am #926752CCrewParticipantBased on that picture the derailleur is installed waaaaay too high. Usually only want 1-2mm to clear the tips of the chainring teeth and you’ve got what looks to be 3/8″
After that jump on someplace like Park Tools site or You Tube for a tutorial on FD adjustments. They can be little buggers, I’ll tell you that.
http://www.parktool.com/blog/repair-help/front-derailleur-adjustments should get you startedJune 9, 2011 at 8:55 am #926673CCrewParticipantBased on that picture the derailleur is installed waaaaay too high. Usually only want 1-2mm to clear the tips of the chainring teeth and you’ve got what looks to be 3/8″
http://www.parktool.com/blog/repair-help/front-derailleur-adjustments should get you startedJune 9, 2011 at 9:52 am #926760JsnydParticipantAwesome! Thanks!
June 9, 2011 at 9:52 am #926682JsnydParticipantAwesome! Thanks!
June 9, 2011 at 10:09 am #926685PrintErrorParticipant+1 to CCrew, looks like an easy adjustment. Your local bike shop can tweak it if you can’t get it to work.
June 9, 2011 at 10:09 am #926765PrintErrorParticipant+1 to CCrew, looks like an easy adjustment. Your local bike shop can tweak it if you can’t get it to work.
June 9, 2011 at 12:30 pm #926691JsnydParticipantThanks everyone. First I’ll try and drop the whole thing a bit but im afraid that it may be bent. The front of the derailleur looks high while the back of it is right on top of the lower gear. I might swing over to CityBikes Inc. and have them look at it.
June 9, 2011 at 12:30 pm #926771JsnydParticipantThanks everyone. First I’ll try and drop the whole thing a bit but im afraid that it may be bent. The front of the derailleur looks high while the back of it is right on top of the lower gear. I might swing over to CityBikes Inc. and have them look at it.
Is that the original derailleur for the bike? It’s not unusual that the curvature doesn’t match perfectly, it’s more about clearance and function. I’d at least give it a shot.
I believe so, I found a site that lists a 95 Arriba to have almost all Shimano STX parts which is the same as I have.
