BAFS 2020 Pointless Prizes: Loopy for Arlington
Our Community › Forums › Freezing Saddles Winter Riding Competition › BAFS 2020 Pointless Prizes: Loopy for Arlington
- This topic has 33 replies, 13 voices, and was last updated 1 year, 1 month ago by
peremaya.
January 20, 2020 at 11:36 am #1103558
ParticipantYes! My number is correct! THANK YOU!
Sent from my iPad using Tapatalk
January 21, 2020 at 2:14 pm #1103604Brandon
ParticipantMine is correct as well, thanks!
February 14, 2020 at 5:05 am #1104493OlgaVsElsa
Participant@obscurerichard 197178 wrote:
Could folks double-check their Loopy rankings now please? We’ve fixed some of the synchronization issues that had freezingsaddles.org showing fewer segments than were reported in Strava.
Just checked and it seems like the one loop I’ve done isn’t on the leaderboards – CW, seems like all 8 segments are there. Just hoping to see a big ol’ 1 next to my name on the board. Curious what the issue could be or if I’m misinformed (definitely possible).
https://www.strava.com/activities/3080131609
February 14, 2020 at 7:18 am #1104494Nadine
Just saw this. I’m counting 18 loops on my strava feed, but the leaderboard says I have 7.
Also it says that the segment I ride the LEAST is the one just outside my house…. my trail access basically – probably one of the segments I ride the most. [emoji848]
I prefer the counterclockwise loop, so most of mine are probably counterclockwise – sounds from this thread like the loops might be being counted with different effectiveness going in the different directions.
February 14, 2020 at 2:59 pm #1104501Steve O
I think it may not be picking up CCW1 because of your privacy zone. How big is your privacy zone around your house?
Here’s your ride from Feb. 4 (https://www.strava.com/activities/3072395021) Note where it starts and ends. I imagine you actually rode from your house, but Strava is hiding your privacy zone and not counting that segment.[ATTACH=CONFIG]21188[/ATTACH]
February 14, 2020 at 3:20 pm #1104503LhasaCM
To build upon what Steve said – for any ride where the segment stops or starts within your privacy zone and is at the beginning or end of your ride, Strava will not count that segment. The times it did count it would be if the segment occurred “mid-ride” (the privacy zone only applies to a ride’s start/stop). Per Strava:
Any segment, regardless of whether it’s a private or public segment, that starts/stops within your Privacy Zone will not be matched to your activity, even if your activity’s visibility is set to “Only You”. However, if during your activity you pass completely through your privacy zone and continue on, that portion of your activity will be visible and you will match to segments within that zone. It’s only when your activity starts or ends inside of your privacy zone that those portions are hidden and segments within your zone won’t be matched. Removing a Privacy Zone will reinstate segment matches and any associated KOMs/CRs. More information regarding Privacy Zones can be found here.
February 14, 2020 at 5:23 pm #1104509DCAKen
ParticipantAnother data point:
[ATTACH=CONFIG]21193[/ATTACH]
This ride wasn’t counted for my only loop around Arlington so far during the contest.
February 14, 2020 at 5:45 pm #1104511bentbike33
Participant@DCAKen 198374 wrote:
Another data point:
Do all 8 segments show up in your segment list for the ride?
February 18, 2020 at 3:56 pm #1104519DCAKen
Yes. I’ve checked the FS Loopy page and my Least-Ridden Segment has shown different segments on the various times I’ve visited the page. Sometimes CW8, others CW2, but when I click on that segment, it shows my results from the day I did the loop.
March 2, 2020 at 4:39 pm #1104915Steve O
ParticipantStill curious about hiccups in the data. The leaderboard shows me with 8 loops, but I think it should be 11.
I checked all 16 segments.My lowest CW segment is CW1 with 4
My lowest CCW segment is CCW8 with 7Thanks.
March 2, 2020 at 5:56 pm #1104950bentbike33
Given the issues with the leaderboard, I’m going to ask the gurus to do the Loop segment data pull that I’ve used in the past to calculate the winners. I’m hoping the issue is somewhere between the database and the leaderboard.
March 15, 2020 at 9:35 pm #1105292obscurerichard
ParticipantCould folks check again about whether their loop count is accurate or not? We’ve made some significant fixes to fetching segments that should grab many more of the segments that did not get counted the first time around.
March 19, 2020 at 9:27 pm #1105385Steve O
Confirming that I believe my count is accurate.
March 28, 2020 at 3:49 pm #1105545bentbike33
ParticipantSince we seem to have settled that the leaderboard is correct, I am ready to award the FS2020 Loopy for Arlington Prizes.
A total of 396 Arlington Loops were completed by 68 Freezing Saddles participants this year, 176 clockwise by 53 riders, and 220 counterclockwise by 44 riders.
For keeping the best balance in life during Freezing Saddles, the prize for Most Matching Loops goes to:
[ATTACH=CONFIG]21447[/ATTACH]For keeping herself totally wound up during Freezing Saddles, the prize for Most Counterclockwise Loops goes to:
[ATTACH=CONFIG]21448[/ATTACH]And, by judges decision (and because nobody needs 2 boxes of Froot Loops), for the guy who likes to unwind, the prize for Most Clockwise Loops goes to:
[ATTACH=CONFIG]21449[/ATTACH]Congratulation to all the winners! PM me to arrange a meet-up if you are running low on cereal. Otherwise, I will present your awards when we eventually have the closing Happy Hour.
March 28, 2020 at 4:48 pm #1105547CBGanimal
ParticipantTHANK YOU! the most awesomeness prize if freezing saddles by a long shot!
