Likes Likes:  41
Dislikes Dislikes:  1
ELITE ELITE:  4
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: What tool do I need (cassette and chainring and chain removal)?
    Jan 2012
    West McLean
    Default What tool do I need (cassette and chainring and chain removal)?
    I want to remove the cassette and chain ring and chain and clean them really well (and evaluate for replacement). What specific tools do I need? Thanks!
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	2015-11-09 14.56.34.jpg
ID:	10053   Click image for larger version.
Name:	2015-11-09 14.56.50.jpg
    Feb 2011
    Westover Beer Garden
    A chain tool for "breaking" the chain
    A cassette tool (potentially called a freewheel tool) for removing the cassette from the hub. You will also need a wrench (25mm?) to turn the cassette tool and a chain whip to hold the cassette in place while turning the tool.
    A crank tool to extract the crank arms from the bottom bracket (and you might need a wrench for that tool as well). I don't know how these newfangled cranks work--it doesn't look like square-tapered, as God intended cranks to be.
    You will lastly need the appropriate hex key (allen wrench) to remove the chain rings from the crank arm.
    Feb 2010
    Leesburg, VA
    To remove cassette: chainwhip, cassette lockring tool, adjustable wrench (to grip lockring tool)
    To remove chainrings: usually just two metric allen wrenches. Sometimes the backside of the chainring bolts use a big flathead (there is a special tool for them but a large flathead screwdriver usually works fine too). Assuming you aren't actually removing the crankset, which you shouldn't need to just for chainring cleaning.
    Chain: nothing if theres a quicklink, chainbreaker if there isn't (and a quicklink to put it back on).
    May 2014
    I have a chain whip, cassette thingy and socket wrench to fit it, all of which I can bring to Kindred tomorrow.
  5. #5
    Jan 2012
    West McLean
    Thanks all - I have a chain whip from messing around with my fixed gear bike but I wasn't sure what kind of cassette lockring tool I needed. Seems like a bunch of different choices. I have an SRAM cassette - so I will figure it out.
  6. #6
    Feb 2010
    Leesburg, VA
    Quote Originally Posted by Subby View Post
    Unless you have something really old or exotic (which it does not appear you do), a bog standard tool like the Park FR5 should do it.
    http://www.parktool.com/product/cass...ring-tool-fr-5
  7. #7
    TwoWheelsDC's Avatar
    Feb 2012
    ALX
    Quote Originally Posted by Tania View Post
    I also have all the necessary tools if you two can't make this work.
    I can't tell exactly what type of BB that is, but you might as well clean and re-lube it while you've got everything taken apart. I have tools for a GXP BB, which I think will fit, since I'm assuming it's a Megaexo or whatever external bearing system FSA uses.
  8. #8
    Jan 2012
    West McLean
    Is this what the BB tool looks like?
    http://www.parktool.com/product/bott...ket-tool-bbt-9
  9. #9
    Dec 2010
    Columbia Heights, DC
    Does the chain whip have to be the same size as your chain? Just wondering if you might have a 1/8 chain whip and a smaller chain on your geared bike and not sure how compatible they are.
  10. #10
    Oct 2012
    Falls church
    Got all the tools and stuff required to tear down, clean, inspect, and reassemble in a clean dry place to work if you want to stop in. In the shop most evenings anyway. Right around the corner from you.
    Jebezus warn me next time. I just looked at the images of your cassett and RD without squinting and peeking through fingers over my eyes. We can tear the drive train down and give it a bath in the heated ultrasonic cleaner while cleansing a couple of bike motors with a beer based solvent flush.
