Likes Likes:  22
ELITE ELITE:  7
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: Chainring
  1. #11
    Sounds worn to me. Suggestion: check eBay for rings matching your BCD & tooth count. Lots of people sell chainrings taken off new bikes for a lot less than you'll pay for a new ring. As mentioned earlier the BCD is probably printed on the chainring -- or the outer one and the # teeth is almost certainly printed on the chainring.
    Edit:
    Another thing to double check: make sure you can replace the chainrings. Some (cheaper) cranksets don't have chainring bolts (they are just riveted together). But probably not yours. Assuming you do have bolts you may need one of those little T wrenches (or whatever they are called) to use on conjunction with a 5mm hex. Hopefully it is a chainring with decent 6mm/5mm hex bolts instead.
  2. #12
    Jul 2012
    I just bought a set of two five bolt Raceface rings, 53/39 130BCD, both for total of $19.95 from Bike Nashbar. Probably too big and too many bolt holes for your bike but if not, pretty good price. I just got them today, hoping they fit my bike. I think they are designed for double crankset, mine is a triple. I should have clearance, stock rings were 30/40/50.
  3. #13
    Sep 2011
    Rosslyn, VA
    I just replaced my inner chainring for the same reason....put on new chain to discover the cassette was worn, installed new cassette and chain to find my inner chain ring was worn. Finally got it right, but being Campagnolo I had to sell the rest of the bike to afford it :-)
  4. #14
    Feb 2014
    MoCo
    Default Middle ring
    My Bad Boy was one of the original "Dark Angel" models, so the cranks are probably different, but I found only "Vuelta" brand rings fit.
    Attached Images Attached Images
  5. #15
    Jul 2014
    Occasionally Arlington, VA. But mainly in Lima, Peru.
    Quote Originally Posted by Dickie View Post
    1. You are a good man.
    2. It is totally worth it.
    3. I have Shimano 105 and Ultegra on two of my rides and Campagnolo Record 10v on my third. It is always so wonderful when I ride Campa. Almost done collecting random parts to shift my commuter over to Campa...
  6. #16
    americancyclo's Avatar
    americancyclo is offline I really need to log off the internet and go for a ride.
    Nov 2010
    Quote Originally Posted by rcannon100 View Post
    Just the middle ring. And I ALWAYS ride in the middle ring.
    I always ride in the big ring on my Bad Boy. You want my middle chainring?
  7. #17
    rcannon100's Avatar
    rcannon100 is offline Puppies! Puppies! Puppies! Puppies! Puppies!
    Sep 2011
    "a minefield of dumb games and social cliques badly disguised as a forum for DC bike advocacy."
    Quote Originally Posted by americancyclo View Post
    YES!
    So the middle is a 38 104 mm. And apparently (of course), that is unusual. Very unusual. So far two LBSs have been left shrugging their shoulders. EDIT: Yeah, even Bike Nashbar dont got it.
    I see online a chainring 38 104mm but it is listed as 10 speed. My Cannondale BB is an 8 speed. That's something I am going to have to match too???
    The last LBS found an old crankset hidden under a rock - but it is a shimano crankset which requires a longer bottem bracket. I got a 118 and it needs a 122? So they are going to order me a new bottom bracket too.
    Is there a difference in quality of chainrings? I mean I guess I dont want one that is rivetted cause I want to be able to swap out the rings. Otherwise??
    UPDATE: Yeah, all I see online is 38t 104mm for 10 speed.
    So that means to fix this I am looking at replacing the whole crank set??
  8. #18
    Feb 2011
    Westover Beer Garden
    Well, if you "ALWAYS" ride in the middle ring, just change the setup into a 1x8 and be done with it.
    The number of speeds shouldn't matter. I think they only put out new derailleurs and cranks for higher speeds so they can charge more. (9 and 10 speed chains are narrower, so are different, as are shifters.)
    118 mm bottom brackets seem narrow for triple cranksets.
  9. #19
    Mar 2013
    Alexandria, VA
    Not sure that 10-speed designation actually makes a big difference. Neither is Sheldon Brown.
    Disclaimer: I am not a professional bike mechanic, and I didn't even stay at a Holiday Inn Express last night.
  10. #20
    Mar 2013
    Alexandria, VA
    Quote Originally Posted by DismalScientist View Post
    118 sounds reasonable to me. My triple crankset is on (and calls for) a 113 mm bottom bracket spindle. 113 or 118 (don't recall which at the moment) is what comes on the stock Surly LHT, which has a triple crankset.
Tags for this Thread
