Likes Likes:  15
Page 5 of 5 FirstFirst ... 345
Results 41 to 45 of 45
Thread: Bike light recommendations
  1. #41
    Amalitza Guest
    I have 3* Lumina 750s. I like them very much. My only negative notes-- the most recent one, the little rubber cover that protects the usb charging port from weather fits so tightly that I can't actually close it, thus negating the weather protection. I think once I manage to get it to close. Once. And for me at least there was a learning curve in popping the light into the holder part that attaches to the handlebar. You need to push it in until you hear it click-- if you** aren't paying attention and stop as soon as you feel resistance it's not locked in place and will go flying when you** hit a bump.
    *yes, 3. I had 2 because I wanted a spare. Then I lost one proving the need for a spare, so I bought another. Eventually, I found the lost one back.
    **or, well, I, at least
  2. #42
    Jun 2011
    Quote Originally Posted by EasyRider View Post
    My thinking on this has evolved a bit since February. Kinda interested in the B&M Ixon IQ Premium described on Peter White's site. Battery powered and has a cutoff beam. Not cheap at ~$100, but seems like it'd be a step up from the Cygolite 300 I've been using the past few years. Anyone using one of these?
    Excellent light--it puts the light where it needs to be, so even though it doesn't have the same lumens as some of the flashlight lights, it does a better job of lighting the road. (It's a much more even beam pattern, so you don't get dazzled by a bright spot in the middle foreground.) I also recommend mounting it lower than the handlebars, which helps bring out road irregularities. (Fork crown or front rack mount.) I supplement with a helmet mounted light, usually on low as a backup, but also as a steerable high beam when off-road (e.g., on trails where you also need to watch for branches). They've been out a few years now, so they're starting to be available at pretty steep discounts online.
  3. #43
    Jul 2017
    I have a NiteRider 650 that I got from amazon. Very powerful and easily mounted.
  4. #44
    Jul 2017
    20854
    The cygolite dash 600 is now 50% off on Amazon. Anyone here use it? I'm looking for something that will get me home on the CCT in the fall/winter.
  5. #45
    Feb 2011
    Crystal City to L'Enfant Plaza
    A quick shout out to Niterider. Sent a 5-6 year old lumina style light back for repair as the bulb was awfully dim. I was expecting to pay the $20-30 shop fee plus parts. It came back yesterday repaired for no charge as they blamed the actual LED which had a lifetime warranty.
    Pretty much makes the decision about the brand of the next light I buy.
Tags for this Thread
