If I remember right, there was a recall about three years ago on the Magic Shine battery pack because of a fire danger. There was a long gap before a new version was on the market. FYI, the links may be marketing placements.
The batteries on the ones currently sold under other names are possibly the same as those ones that were previously sold under the Magicshine brand (they look identical) and I think the case of one exploding I heard about was within the last year. There are a couple sites now selling the Magicshine branded lights with fancier battery packs which are probably safer. (The cheap battery packs are just four 18650 batteries wired together so you could probably get batteries with built in protection circuits or use a charger that's more intelligent about knowing when to stop the current.)
I had heard about the fire issue and recall on MagicShine stuff as well. So far, I find that the batteries charge in about three hours, even when completely discharged. So I tend to recharge them at work, and I can babysit them while I sit at my desk.
My end goal is to build up another dynamo hub-equipped front wheel and get a new Busch and Muller Cyo N headlight like the one I used to have. It sure was nice not having to worry about charging batteries!
just an update, I purchased the NR Minewt 650 and mounted it on my bars. For those of you that have this, do you use the flash mode on trails and roads? It seems really bright compared to the highest setting and im not sure if it is blindingly bright to oncoming traffic.
Please please please turn off strobes on the trail. You dont need them on trails; and you are blinding your oncoming cyclists. First all I can see is light; then all I can see is darkness. And my eyes dont adjust fast enough. Please - go to solid and point it down at the trail in front of you - not into oncoming cyclists eyes.
Thanks!
No strobes on the trail please
And even with the steady light, be sure to dim it with your hand, or redirect it for oncoming traffic, especially when it's completely dark.
My knowledge of electrical circuitry is not what it should be, but this sounds like a cool project. Any ideas how you'd make it work? I think dynamo hub output is AC and battery powered lights run on DC. Voltages are all a little different, etc.
Keep me posted on how it goes if you do try to wire it up!
