Likes Likes:  0
Results 1 to 4 of 4
Thread: Rear wheel wobble - serious or silly?
    Nov 2010
    Claremont (Arlington)
    Default Rear wheel wobble - serious or silly?
    Looking at a potential used bike purchase. Noticed that the rear wheel is not true (has a sideways wobble each revolution) and that an odd noise occurs each revolution when the bike is ridden. The noise does not happen when I lift the bike and spin the rear wheel with no load on it.
    The bike's owner noted that a given spoke in the rear wheel keeps comi loose, and that it was loose at the time, thus possibly being the cause of the noise. Is that normal? Is a wobbly wheel anything to worry about? The own thinks that the bike has about 250 miles on it. Serious concern or silly and simple to fix?
    Dec 2010
    Herndon, VA
    Serious concern AND simple to fix. If the owner is not a wrencher, simply take the wheel to your local bike store and ask them to true it. A loose spoke will cause uneven tension on a wheel, causing it to bend out of true. Worst case scenario, more spokes come loose and the wheel ultimately fails.
    Since it's most likely not a $$$$$ race wheel, it should not be that expensive to fix. Any competent bike shop can take care of it.
    baiskeli's Avatar
    baiskeli is offline I really need to log off the internet and go for a ride.
    Dec 2010
    If it's been really wobbly for a long time and not fixed, the rim could be twisted or cracked, and that would make it harder or impossible to fix. There's a small chance you'll need a new wheel. Probably not a huge expense though.
    Mar 2011
    i recently purchased a bike with a wobbly wheel for cheap. part of the issue was the rear cones were loose, but the wheel was pretty damaged from being ridden on while wobbling. i ended up replacing the wheel, which was about $50. the bike now rides just fine, for the most part.
Tags for this Thread
