Likes Likes:  7,422
Dislikes Dislikes:  72
ELITE ELITE:  584
Page 173 of 673 FirstFirst ... 73123163171172173174175183223273 ... LastLast
Results 1,721 to 1,730 of 6726
Thread: My Morning Commute
  1. #1721
    Tukwila, WA
    It's a good thing we got that rain. Last night, almost everything near me (Ballston area) was covered in what seemed like a sheet of ice.
    Quote Originally Posted by guga31bb View Post
    ...the overpasses are apparently made out of some sort of magical cold-retaining substance...)
    Here's an explanation of why the overpasses are always the coldest: http://science.howstuffworks.com/nat...uestion566.htm
  2. #1722
    Dec 2010
    You raise a good point.
    It's not bad enough to need studs more than occasionally. Almost easier to just ride on the road and not deal with switching things out.
  3. #1723
    Dec 2013
    Falls Church
    Call me a wimp but a day like this takes all the joy out of the ride. I took Metro.
    Those of you who use studs, what do you do, keep a second set of wheels? Or do you actually change the tires when you need studs?
  4. #1724
    ShawnoftheDread's Avatar
    ShawnoftheDread is offline I really need to log off the internet and go for a ride.
    May 2012
    Annandale-Downtown
    I switched to the studs and was glad of it. I could have gotten by without, but in several spots on both the trails and the road I was a bit more confident because of them. I'll just be extra slow going home.
    I got replacement wheels a few months ago, so the studs are mounted on my stock wheels. That would have made for a very easy switch if the old wheels weren't slightly narrower, requiring a brake adjustment too.
  5. #1725
    Feb 2011
    Westover Beer Garden
    After sleeping in, the roads were fine on 28s. I was going to go over the Key bridge because it is shorter, but force of habit put me on the TR bridge. The troll bridge was a mess but OK at 10 mph. Not many had passed over the TR bridge since TwoWheels.
    Last edited by DismalScientist; 12-09-2013 at 10:20 AM. Reason: To all you haters out there that ELITED my first post, have you ever seen me without my extra Monday morning beauty rest?
  6. #1726
    Feb 2011
    Quote Originally Posted by Geoff View Post
    It's a lot easier just to change bikes.
  7. #1727
    Nov 2013
    DC
    Default Dry feet equipment breakthrough
    Around 7 A.M. this morning, when it was time to bike to work, it was raining. I've got spandex shoe covers but they keep my feet dry for maybe five minutes when it's raining before I start to feel the water soaking my sock and shoes. This morning I had a breakthrough. After putting on my cycling shoes, I put each foot in one of those thin plastic produce bags from the grocery store. Then I pulled the spandex shoe covers on over the bags--instant waterproof layer. The tops of the bags were secured under the elastic cuffs of the rain pants so my shoes and socks were all waterproofed. Clipping into the pedals punched holes in the thin plastic, but only at the clips. It worked--when I took off the rain gear at the office, my shoes and socks were completely dry.
  8. #1728
    Dec 2009
    Quote Originally Posted by aguy7 View Post
    Just make sure not to sweat too much, because then you'll get wet from the inside out!
  9. #1729
    Dec 2010
    Different wheel sets for different tires.
    But then, I also switch cranks and chains because the gearing changes based on the tires and intended use. Pedals change, too, and the oh-sh*t brake comes off to accommodate the fat studded tires.
  10. #1730
    TwoWheelsDC's Avatar
    Feb 2012
    Navy Yard
    Yep, second set of wheels.
Tags for this Thread
