Likes Likes:  22
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Cygolite Metro Light
    Nov 2017
    Default Cygolite Metro Light
    This morning my front light started randomly changing settings and turning off. I now have it charging, and it's randomly turning on. Is there any way to fix it? It hasn't had any recent drops, and (otherwise) works great. Hate to have to toss it! Help!
    Judd's Avatar
    Sep 2015
    Quote Originally Posted by smb9600 View Post
    Iíve had this happen with a Bontrager Ion. My internet sleuthing indicated that it was likely water got inside. In my case it was no longer useable.
    I also washed a rear light in the washing machine once. It exhibited similar behavior and I had to toss it.
    Nov 2017
    Oh boo! I guess that makes sense why it happened today... Maybe itíll dry out???
  4. Likes Judd liked this post
  5. #4
    Dec 2014
    Falls Church
    Sounds like the switch is going south in or gotten wet. These are usually soldered to the main board and difficult to fix. If it had gotten wet recently, you may want to remove the battery, leave the compartment open and put it in a closed jar with some uncooked rice overnight. If not, then it would likely be a warranty issue, if it still applies.
  6. Likes Judd liked this post
  7. #5
    Mar 2012
    I’ve had this happen with a Bontrager Ion. My internet sleuthing indicated that it was likely water got inside. In my case it was no longer useable.
    You should've put it in the dryer.
    Yes, I play a flashing rear light engineer in the television.
  8. #6
    Nov 2017
    Oh boo! I guess that makes sense why it happened today... Maybe it’ll dry out???
    I have a Cygolite HotRod front light (I think that's what it's called) and water got in probably 6 months ago, and there was visible moisture. That dried out, but it still doesn't reliably function, so don't get your hopes up.
  9. Likes smb9600 liked this post
  10. #7
    Nov 2017
    Boo! And thanks all! I guess itís time to upgrade... maybe Iíll buy one with a video recorder???
  11. Likes Judd liked this post
  12. #8
    Nov 2013
    Bethesda, MD
    You could also contact Cygolite. I've had excellent experience with their customer service and repair service.
  13. Likes smb9600 liked this post
  14. #9
    Judd's Avatar
    Sep 2015
    Emm and I are both running Fly12 cameras that also have a light. I rarely use the light part of it but it did bail me out once or twice when my main light died.
  15. #10
    Judd's Avatar
    Sep 2015
    Lights and motion also has a new Rando 500 light that has twice the run time as their normal lights.
  16. Likes Sunyata liked this post
