Likes Likes:  1
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: bedding brakes in for a commuter: why bother?
    Sep 2013
    Alexandria
    Default bedding brakes in for a commuter: why bother?
    A year and a half ago I bought my daughter a bike with mechanical disks online. Assembled it, adjusted the brakes, and that's it -- no attempt to break anything in. It's been fine.
    This year I swapped the fork on my canti-equipped commuter bike so it has a mechanical disc brake up front. I'd read a bunch about the importance of bedding in brakes, so I tried Art's Cyclery's method -- 10-20 times of starting around 15-20mph and slowly decreasing speed to 3-4 mph (walking speed). Trouble is, toward the end, I heard a bit of squealing each time. Did I do this wrong? Do I need to clean my rotor and sand my pads and start all over? Is there really any point in bedding in brakes for an on-road bike (assuming I can avoid panic stops for the first week)?
    FWIW the calipers are Avid BB 7 Road S, with the stock steel-backed organic pads, using Shimano SM-RT56 rotors. I'm pretty sure I didn't touch the rotor or pads. I did not bother cleaning the rotors (rotor, pads, caliper are brand new).
    Thanks,
    Peter
    Feb 2014
    I never remember to bed in my brakes when I get new pads and I have never had a problem. But... all my disc brakes are hydraulic. Not sure if that makes much difference, though.
    Dec 2015
    I bedded in BB7s the fist time, but have not since, for those or Shimano hydraulics. I just let the first ride be the bedding in and haven't noticed a difference. I suppose that as long as the levers don't immediately start going all the way in to the handlebars it's okay, and of course if one brake does, you still have the other.
    Feb 2014
    MoCo
    I'm with Sunyata. Many, many pad replacements without bedding, but all hydraulic (about half Tektros, the rest a mix).
  5. #5
    Oct 2013
    Arlington, VA
    I've replaced the pads on BB7s many times, and didn't know bedding was a thing.
  6. #6
    Mar 2016
    Virginia
    I had a similar noisy experience with new pads and rotors on used BB7s this weekend. I didn't touch the rotor faces while installing, but I didn't degrease them either. Probably should have. Will try that before testing again.
  7. #7
    Mar 2015
    Falls Church, VA
    Seems to me the whole pad bedding recommendation is a way to get you to practice some panic stops in a non-panic situation to: (1) make sure everything is still working correctly after the installation (e.g., no misplaced lubricant) and (2) give you advance warning of any change in braking characteristics caused by the new equipment.
  8. #8
    I generally bed in new pads. I don't think that there is a noticeable performance difference, but bedding them in leaves me confident that my brakes will stop the way I expect them to. (Brake strength improves noticeably after a bunch of those bedding in slow-downs.)
    As for the squealing .... I would guess a contaminated rotor, though I have had some pads (jagwire scintered come to mind) that are just noisy pads. I switched back to organic on my commuter so I don't scare peds when it is wet out.
  9. #9
    Sep 2013
    Alexandria
    What's your preferred technique?
    Yeah, I've rubbed the rotor down with isopropyl alcohol, which helped only for a bit. I think I might pull and lightly sand the pads next. Supposedly the brakes ship with organic pads, but I wonder if they're more metallic than my resin-only Shimano rotor likes.
  10. #10
    Quote Originally Posted by peterw_diy View Post
    I think I use the same technique: accelerate to 15-18mph then brake smoothly back down to walking speed and do that a dozen or so times.
  11. Likes Starduster liked this post
